Vibration In Clutch Pedal- Normal?
Ekstrom
Past 3k when I change gear, I noticed a vibration through the clutch pedal when depressed
Is this normal for a compressor model?
Mine does the same. Think it's a resonance as it only happens between certain revs.
Can't say it's worried me at all. :)
its normal if you have the old clutch but there is an upgrade available - get it changed through warranty
ye m8 mine is a 2003 model and i defo feel that weird feelin just good to no others get it aswll.
When did the "new" clutch come out? Must be recent if Compressors don't have it...
i had clutch changed end of 06 which was modded from the original but i had the clutch replaced again in august and the part had been upgraded again - so somewhere between them two dates. the last clutch i had vibrated but this new one doesnt so i'm assuming you have the old one. hope that helps :thumbsup:
