Engine Management Light On And Off Of Avensis 1999
sam74700
Hi
I am new member. I bout Avensis 1999 1.8 GLS Auto with milage of 58000 just last week.
I got few problems if any one could help me plz
1- Engine Management light comes on and then after 10 mins goes off.
2- RPM meter is not working while every thing else in speedo meter is working
3- Electric sunroof is not sliding to open
sam
the engine is probably fine. most likely the sensor as it is a common problem on the avensis. also the speedo should be fine, unless its been fiddled around with in the past????
so do I NEED TO CHANGE THE SENSOR?
