Engine Management Light
bobspencer
Hi Has anyone else had problems with the engine management system on a RAV 4D (2006)The engine management light keep coming on for no reason. This has happened 3 times. Toyota can not find any reason for the problem. They keep resetting the engine managment and replaced the injectors at less than 30000 miles. Any thoughts please
Bob :unsure:
Hi Bob, think Anchorman is your best bet here, he may be on later. :thumbsup:
Bob :unsure:
As with all of these, the ECU will store a code as something must have triggered the light to come on. Get your dealer to give you the codes stored in the ECU and we can then tell you what may be wrong. Also why did they change the injectors at such a low mileage.... :unsure: What time did it happen, straight after staring or after awhile...sorry for more questions but it will help us identify you problem quicker and hopefully help you out.....
On earlies tomorrow so won't be around until later in the day. However, for the time being, Chatman has asked all the relevant starting questions :thumbsup:
