Steams Up Very Easily!
boabytsportin
hey all
since a got the car 3 weeks ago i noticed that it would steam up really easily and there for had to turn the de mister on but even that barely stops it some times. i have full leather could this be the problem? any of u have this problem cos it a pain in the a**e cheers.
hey all
Have you got your recirculating air switch set to recirculate cabin air?
You will steam the windows if it is set like that as there is no fresh air being drawn into the car.
I don't think the leather would make much difference :)
might be worth checking the pollen filter make sure it is,t blocked :thumbsup:
The blower MUST be on and set to fresh air (not recirc) and as mentioned above, a quick flick with the A/C switch will clear it in seconds
Kingo :thumbsup:
I find if u switch on the aircon u hav to leave it on, bcos once u switch it off it steams up even quicker. i used to drive a Focus and its got demisters on the front screen, it comes VERY handy. i wonder y other companies havnt added this addition :unsure:
Having the A/C on for long periods really makes for a dry atmosphere, as soon as you turn it off, the damp air we suffer from in this country soon has it condensing on the screen. I find having a nice clean screen on the inside, with the blower on at least one notch, helps to keep it all clear
Kingo :thumbsup:
I think ford have patented the design so no one can copy it. I'm sure its great for those frosty mornings.
ye cheers lads but av done all that but av not ckecked the pollon filter al do it later its just a pain in the a**e cos not even ma punto did it that quick aw well cheers any way.
You could try STOPPING BREATHING whilst in your car :P :lol::lol:
i bought my yaris and suffered from this for about a month. tried everything and no luck. then noticed the recirculating air. switched it to fresh air and sorted the problem in 2 mins and i've never had the problem since
haha .
nah av tried all that only seems 2 b wen its rainin but that must just be the humidity.
Nope, other brands have it too. Not too difficult to put an element on glass.
Slarti is right. You can only have it if you buy a Jag/Landrover/Ford or An Aston.
haha .
do you smoke? the window lets in alot of water, i had a similar prob so stopped smoking when it rains
Which are all tied in with Ford. :)
Some good advice in the above comments. However, I always thought that Toyotas seemed more prone to misting up than some other cars that I have driven. I've noticed it on Corollas (Executive, T-Sport and T-Sport Compressor), a Carina E and two Avensises (Avensii?).
I try to keep the inside of the glass scrupulously clean and I use the air conditioned demist setting at high temp to avoid chilling the glass. Air-con dries the air as a consequence of its pressure cycle and helps make a speedy de-mist if used appropriately. When the car is warmed throughout the air-con assisted de-mist is seldom needed.
i think the corolla clears quite quick - i cant compare to other newer cars, but is certainly better than my last corolla and i use a carina e for work which seems to take ages on cold nights/morning to clear.
