My T Sport Needs A Service...
Ceri
Hello,
I bought my T Sport in August and it sounds like it needs a service. The previous owner didn't look after very well. Could anyone advise me on how much it will cost and where the best garage to take it to, a Toyota approved garage preferred... I did a search on Google to find a Toyota specialist but had no joy…
Ceri :D
Seen as you live in Flint, Take it to lindops in wrexham.
I've never had a problem with them, i'd recommend them over any other in the area.
Your talking £90ish for normal service or about £160+ for a major service depending on what they do and what they may need to change.
Hello,
Ceri :D
How can it sound like it needs a service!?!
Hello,
Ceri :D
If it "Sounds like it needs a service" and "The previous owner didn't look after very well." you just might find that it could cost a few pounds more :(
Hello,
Ceri :D
Exactly what I was thinking! Not a good time of year to be spending big bucks so hopefully it is just the service it needs!
Thanks think I’ll just do that then...
Should be running smoothly again in no time :)
Just to let you know (anyone that wants to know that is)
I have booked my car in at Wrexham and the cost is £186 :thumbsup:
That’s for an oil change, break fluid etc...
Kwik-fit is the best I've heard of.
Full service includes everything, Oil and Oil Filter Change, Check and Refill Brake Fluid, Anti-freeze Coolant, Windscreen Wash, Power Steering Fluid. Essential Checks, Lights, Windscreen Wipers, Battery Charge and Condition, Exhaust Emissions and Condition, Visual Brake Check, Tyre Tread and Pressure, Full Brake Check, Steering Check, Shock Absorbers Check, Suspension Check, Belt Check, Wheel Alignment, Replace Fuel Filter (Diesel), Spark Plugs, Air Filter, Free Wheel Balance, Wheel Bearing Check, Brake Fluid Condition, Fuel Treatment, Brake Efficiency Check, Lambda Sensor Check, Emissions Check, Carbon Offset.
Full service includes all of that. And price for all of that for a tsport PLUS an MOT is only £160!!!
Cant go wrong really.
Plus its a nationwide recognised garage so no dodgy dealings or anything.
Quite good in my opinion.
