Corrola Power Steering Noises
westroyd
I have A Toyota Corolla 1400 D4D on a 54 registration so it is just out of warrenty !!! A noise similar to hydraulics running on a bypass valve has started when I rotate the steering wheel to turn right. No noise happens when I steer to the left. The noise is comming from just behind the dashboard on the steering collumn. I believe the power steering on my model is electro mechanical through a motor/gearbox, so why the squeeling, hissing hydraulic noise? Can any one help identify the cause?
Ta
