Fuse Box St185 Import
markd1984
were is the fuse box holder for the likes of the heaters and elextric mirrors on a GT4 st185 import? the only ones i can find is the main ones under the bonnet
cheers
cheers
Try driver's side kick plate; bit of a pain to get at and I'm not sure those particular ones are in there, but there certainly are some, and if the ones you're looking for aren't under the bonnet then that would be favourite.
Yep as said above look in driver side kick plate. There will be a collection of fuses in 3 rows of 3. Top left is fan/heater and next one across is mirrors :)
  • 4 years later...
Have you heard of them being moved at all? only found 3- one 10amp, one 30 i think and a 75.... just to the bottom left of where the glove box is
