Brake Pad Question?
dmacdou1
Hi all, does anyone know if the rear brake pads on the new model(2003- now) are the same as the front pads?
I ask because i got the telltale grinding noise that means "new pads required" when braking the other day, so off i went and bought new pads. Proceeded to remove the pads from the front and found that they were fine, plenty of life left in them. I changed them anyway since i had the new ones there, then realised that its discs all round on this car, so i'm wondering if the rears are the same, then can i just fit the ones i removed from the front?
Not sure if they are the same, though i doubt they are.
I wouldnt recommend it anyway, as the pads you removed would be worn to the shape of the front discs. your better off fitting new ones.
Paul
No they are denfinitly NOT the same
Kingo :thumbsup:
