Avensis Accelerator Pedal Stiff In The Mornings
bigup
hi guys
for the last 2 months, ive noticed that my accelerator pedal is stiff in the mornings.
when i get in to start the car, i have to press hard on the accelerator pedal to "release" it, once i do, the accelerator is perfect, moves freely and works fine for the whole day.
this only happens in the mornings
any have idea what is causing this and what the solution is?
thanks
i am sure the 1998 avensis were cable throttles,
I would look at greasing the throttle cable.
and.. greating the throttle spring.
with not grease, but pentrating fluid..
The valve where the acceleratorcable is hooked on for the air to come in the engine is DIRTY clean it and its over cause the valve has to come OVER the DIRT in the morning cause its coold down
sorry for my bad english
You can take it of just unscrew the 4 bolts and clean it with BrakeCleaner Thats a spray , spray it in and afther a few minutes cleaned with a clean cloth
excellent! thanks for the information!
am i looking in the engine bay for this, or at the actual pedal inside the car?
engine bay.
Look at the hose that comes from the airfilterbox TO the engine , That hose is fitted on the accellaroterhouse look at the pic ;)
