Wrong Fuel Economy/mpg Reading
DairyleaMonster
Hi there - hope someone can help with this
I have an '03 Avensis T3-S 1.8 with about 88k on the clock.
I think it is showing the wrong fuel economy on the onboard computer. It reads about 43mpg, when my calculations are roughly between 32mpg (if you use US gallons) and 39mpg (if you use imperial gallons)
Or put another way, for about 50litres of unleaded, I can do about 430 miles.
So is something faulty? Or is there anyway I can reset the computer and get it to read correctly? Or are my calculations wrong?!? :unsure:
Yours confused and needing help!
Baz
Yes
you can take out the ECU fuse,
or disconnect main batt negative for 15 mins
btw the onboard computer is not 100% accurate
Ok - thanks for that
Will I need a code for my CD/radio player - have had to do it in the past on other cars
Cheers!
Baz
I would not bother to do it, if it says 43 and u get 39 on the calculator then leave it as is, doubt
you will get any better readings than that. Treat it as a guide. It will reset after each fill-up anyway and then give
you an expected 'range'. Not usre how it calc's the range itself, maybe based on average consumption over a certain time/milage.
Yeah - saw that it reset after every fill up, but was wondering (hoping?) that there was a manual override.
Oh well - I'll just stick with doing my own calculations then
Cheers!
Baz
Cheers!
Baz
Hi, the problem with your feul comp stems from a faulty combination meter,this supplies the comp with inaccurate info!! Changed loads at work!! Hope this helps.
Ahhh ok thanks - is that something that the warranty would cover?
Baz
Baz
HI,no i dont think theres an extentsion on the standard 3 yr wrnty,,,,sorry!
Nightmare! :lol: oh well - worth a try wasn't it!
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
