Hazard Light Button
zetor
Hi, could anyone please tell me if my hazard warning light button on the dash should be illuminated all the time? I notice I cannot see it at night, if it should be on how do I get access to the bulb, does the button just pull off?, thanks.
Zetor
2006 Corolla D4D
lol mines gone in my ae101 rolla!
tried taking the back off and its a complete unit, bulb and button and back bit so it looks expensive, i know where the button is, above the rear de-mister so it doesn't bother me, but yeah it should bee on when the lights are on, like the heater controls and stuff
Gaz
i thought mine had gone, as well as the heated trear screen button, but on closer inspection, they were ok. then they started working, then they didnt, then one at a time, now they're both out again. i'm really beginning to dislike this car...
It's not on all the time surelly only when the hazard button is pressed, Just go and push it in and see if it comes on...
If the bulb has then gone, push the fan heater things into their upmost position then pull and the bottom of them (they will unclip and pop out) then you will see above each of them that there are 2 clips (one on each side) just use something pointy and pull them down and the whole air unit will pop out of the dashboard very easily then there is a plug on the back of the button that you can undo then change the bulb.
You have to do all this to get to some bolts to change your head unit too if you havn't already done so ;) I have just changed mine thats how I know
Collin
