Broken Heated Rear Windscreen
bassett19
Hi All,
The heated rear windscreen on my 1999 avensis isnt working. It would be great if anyone has any ideas where to start looking to see if i can fix it myself.
Easiest ones would be check the fuse and examine the lines on the screen to make sure none are cut / damaged. Then disconnect the wires by the screen and use a mulitmeter and push the switch to confirm it's getting power.
Hi Bassett19,
I had this problem, the switch illuminated but there was no de-misting taking place. The blade connectors soldered to the screen heater had become detached. I did try some conductive adhesive but this was unsuccessful. I didn't enquire how much a new screen was, I just manage with the air con now.
I hope you can repair yours!
vmax1
hi there also have the same problem The heated rear windscreen on my corolla 03 isnt working. do i also have to check out the fuse and if yes where will it be located??? in the fuse box??
