thnx guys i appreciate it.
Paseo Guy you may contact Back-Yard-Productions 305 249 4979 re 5EFHE. These engines go really fast when the shipment comes, good luck.
5efhe_entity:
I am using the CT-9 turbo/wireloom-harness/ecu in my Tercel and this engine is extremely efficient and gives excellent mileage even driving at triple digit speeds 93 Octane.
artmull
wow...how many miles/km can you get on a full tank of gas? and what is a full tank of gas for you guys? for us in the states a full tank of gass is 10.9 gallons for the paseo and the tercel. one post said for the starlets is 32 liters=8.6 gallons.
on more question ...what is the common idle(rpm) for you guys...and at what rpm are you guys at @ 70mph(112 kilometers/hour).
for me at 70 mph i am @ 3,600rpms. @ idle i am at 1,500rpms. my timing is set @ 24 degrees(i believe this is in part due to the fact that i am using an american paseo ecu ,harness, and injectors).
I tried it with the timing at 10 degrees before, but the 5efhe had no power and my old 3ee SOHC was faster. So i was told to up the timing cause the 5efhe gives off its spark at 10 degrees.
