St205 Owner-help Needed
cfcdoc
need to replace brake light on drivers side, how do i get access, ive taken the trim off and found what appears to be 3 pins in different locations with a washer on them, do i undo the washers and then the lighting assembly comes off?
as far as i can remember yes. the whole light assembly comes off and the bulb holders are in the back :thumbsup:
