Fault Codes
markd1984
hi can any one help me am getting two error codes i know what one of them is but cant find what the other is here is the sequence i got
flash,flash pause flash = 21 oxygen sensor
then
flash, flash, flash pause flash falsh = 32? cant find that one any ideas
the car seems to run fine and i have only had it a few weeks so should i just reset these codes and see if theycome back?
cheers
ST185 Code 32 is Air Flow Meter
If all is running well, definitely reset the ECU by pulling the EFI fuse and see if the fault codes reappear.
av reset the ecu and all seems well now thankfully done about 100miles since and no error codes av re appeard
cheers
