Oil Light
Ok, this is annoying me now. The oil light keeps on commig on intermitntly. and its got oil! I toped it up and it went off for a wile. But now its comming back on when im sat ideling. If i go around a corner or aceletate. It goes off.
I have been keeping a very close eye on the levels of fluids. The car has lost none! the oil had acutaly gone up because i toped it up. the coolent is fine
Im confused to what it could be
Any help would be great
Sam
there is a oil sender in your sump, my plug actually broke and i had to bodge it up to stay in there, now oil light is fine
is on the right side of your sump just check maybe it is loose
fair out question. is it possable oil isnt getting to the sump? were does the dipstick measure from?
could be due to oil leaks maybe aswell, and low oil pressure, also check wiring to the oil sender as mine went brittle and broke lol so that may be worth checking
Could be a number of things.
Is it an oil level warning light or oil pressure warning light?
Faulty sender:
The sender usually only registers when oil pressure drops to around 9/10 psi so any fluctuation caused by surge or when on tick over will show up once the oil is warm.
The other problem can be a worn engine :(
When the engine is cold the oil is thicker and all moving parts a little tighter, the warmer it gets the thinner the oil and the wider the tolerances, the only sure way of checking would be a pressure gauge so you can see what it is actually running at (anywhere between 60/80 psi (check manufacture))
Les
its a low oil level, not the presure level. I just checked. its probably no cause for consurn. but i wanted to be sure
Not bad then :thumbsup:
As long as you don't overfill.....that can be worse than low oil :shutit:
Les
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
