Fluid Loss
mr tiler
:huh: I am losing oil and water, i have checked the obvious places, there is no oil or water on the ground or water in the oil,does any one have any ideas as to where else to look or what the problem could be.
Thanx
Thanx
Hows your power? Is it running like crap? I just got a call from the mechanic on mine. Burnt exhaust valve, allowing blowby of gas / compression. It was caused by a long going mysterious oil loss. It fouled the valve so bad it wouldn't seat anymore. Check out your rear bumper. Mine was black with soot from burning oil. You may have a small crack / rip in your head gasket too allowing loss of coolant, and it could be going out the tail pipe with your burnt oil. Mine never leaked or had sludge in the oil or water. It got by bad oil seal rings that I procrastinated fixing, now I have to rebuild the head too.
Thanx
thanx mrbell as you can see by my last post i have just found out that the head was cracked
