Mirrors
mrbilly
hi
is it possible to fit heated mirrors to my rav i have seen the mirror button (pn: 84871-42010)
cheers
I don't see why not if you have a source for them. Where will you fit the propane bottle??
does kingo get parts, maybe could he look into it (hint)
Yep Kingo's yea man for parts (Parts-King) He is a parts manager for a large Toyota garage in Chester or somewhere up north past Watford :lol: :lol:
PM him or he will be on soon (unsure if they start work as early as the rest of us)
Interesting one, there is a heated mirror switch listed, but we never had that spec in this country, the specs are for left hand drive and Australia only. I have the part numbers but no prices, if you could get the mirrors, you would have to find a way of wiring them, because, not being for our European spec, the loom is not going to be the same, you would end up hard wiring it, so not an easy job. Upgrade to a newer model :D:
Kingo :thumbsup:
Kingo :thumbsup:
Ah telt ye MrBilly - twa hot-water bottles = £20 oot o Asda!! As they get cold, heat them oan tap o the engine!!
Kingo :thumbsup:
Surely...When I turn on my rear Window heater button...the mirrors also come on and clear any mist/water etc... there is no separate switch..All the car's I have had have had the same setup...aprt from Fords that have two buttons, one for front screen and one for rear....
Kingo :thumbsup:
Must be a 5 door glitch?
ma Punto disnae have heated mirrors when a switch the rear windie heater oan. Ah'll ask the dealer.
Yea that's only too keep your hands warm while you push it.... :lol: :lol: :lol: :lol: :lol: :lol:
Kingo :thumbsup:
My early 2000 3 Door GXS has heated mirrors and has a separate switch on the left of the centre console next to the circular blank that I cut out to fit an oil pressure gauge.
Described as 'defogger switch' in owners handbook.
We're looking at a 4.1 here, they don't have heated mirrors. The heated mirrors on 4.2 onwards come on when you switch on the heated rear window. The 4.1 LHD and Australia version have heated mirrors with a seperate switch, hope that clears it up
Kingo :thumbsup:
Push it? It daes 50mph in 2nd gear - ah cannae keep up! 20,000 miles an its oan its 2nd clutch....
Kingo :thumbsup:
Defogger switch is the rear heated window, is yours a RAV 4.1 or 4.2?
Kingo :thumbsup:
Kingo :thumbsup:
Kingo :thumbsup:
It's a RAV 4.1, the heated rear screen 'defogger switch' is on the left upper centre console next to the emergency flasher switch.
The mirror 'defogger switch' is on the left of the lower part just above the ashtray in a bank of four (middle two are blanked off and the right hand one is the headlight beam control).
If I could use a digital camera and PC as well as I can a socket set I would send a photo!
aiberdonian is correct parts king, the switch is on the very left of the pannel to the head lamp level switch, the blank he mentioned is the additional cig lighter blank.
i am also looking into this and have found the loom is present behind the panel, and the mirror loom in the doors has the additional wires. all i can see that is needed is
1. switch
2. mirrors (best from a scrappers)
NOTE: i have not yet checked if relay and fuse is needed or if it uses the rear window circuit.
i am a toyota tech so i could look this up in the workshop manuels
1. switch
OK, while yer at it, send me some wired mirrors too please - I don't have that luxury either.
