Keep Full Toyota Service History Or Go Independent For Service?
bigup
Hi guys
Im due a Service A (90K) service on my Avensis 1.8 GS, 1998.
This will be my first service since owning this vehicle (purchased with 81k on the clock)
firstly how much approx does it cost for a Service A at Toyota?
also im considering taking it to an independent garage, are there any disadvantages of this? of course i will get them to stamp the service book, will it knock any ££ off the car value for when i come to sell it (not for at least 2 years yet!)
thanks!
It's absolutely pointless paying Toyota for a major service on a car of that age and hoping that it in some way helps it to retain some value. You would be better saving your money and having the service done more cheaply at a local garage because the car is worth little in resale value terms. I own a 2001 Avensis GLS in black which has various goodies over the standard model but realisticly I know it's worth next to nothing with regards to resale value.
I have no idea what you're expecting in terms of resale value for a 1996 model but I think I can safely say that the price of a Toyota full service will probably come pretty close to the resale value of your car! I wish I was kidding, believe me. :(
thanks for the reply mate
i was thinking the same, will take it to a local garage for a service
i mean i can do it my self but i would like to get a stamp in the service book
Do it yourself and buy a genuine Toyota Filter etc. That way you have a document which can demonstrate to any future purchaser that you serviced the car on or around the date of the receipt.
thanks gazza
has anyone got a list of what is required for a Service A, i.e what needs to be changed?
Get yourself a Haynes manual, will be in there. To be honest as it's the first one while you have had it I would be inclined to do as a minium oil and filter, fuel filter, air filter, plugs. I don't know if the pre-VVTi engines are belt or chain driven, if it's a belt I'd do that as well. Cam belt is usually one of the first things I change when I get a new car purely as a precaution.
I have a Haynes in my car, I'll have a gander later and let you know what they reccomend.
Hey!
Here is the service schedule according to Haynes.
5000 miles / 6 months oil and filter
10000 miles / 12 months check drive belts
clean air filter
check bettery
check auto trans fluid
check brake pads and discs
check wheel nuts tightness
lube locks and hidges
20000 / 24 months
change pollen filter
check coolant strength
check and adjust brake pedal
check and adjust handbrake
check hoses
check man trans fluid
check exhaust sys
check evaporative emission control
check steering and susp components
check driveshaft an cv joint gaitors
renew brake fluid
check for body corrosion
renew remote locking Battery
40000 miles 3 years
renew air filter
renew coolant
renew spark plugs (except engines with platinum tipped plugs)
renew fuel filter
renew transmission oil/fluid
60000 miles / 6 years
renew spark plugs (engine platinum tipped plugs only)
renewn timing belt (pre august 2000 models only)
check and adjust valve clearances
Have fun!
