Booked In With Toyota
Demo_202
Just booked the car in with Toyota for Thursday to get a few niggles sorted (under warranty)
- Squeaky clutch when cold/ groans when pushing the car slightly
-Alarm (bonnet sensor)
-Rear washer squirts pretty much anywhere
-Drivers side seatbelt clicker squeaks like a !Removed! when even going over small bumps
- Passenger side boot lifter is all rusty (Drivers side is fine :S)
Shall post an update when I get it back, see what was sorted. how do you think' they'll score?
-Drivers side seatbelt clicker squeaks like a bitch when even going over small bumps
they should sort the clutch squeek - common. my seatbelt clink clunk squeeks but not to bad. when it gets bad will take it off n put some white grease behind it. bit surprised about boot damper - must have leaked?
My corolla is going in to toyota tomorrow fo rthem to have a look at my my squeaky clutch, be interesting to see what they do to both cars and what they say caused it.
I used to love taking T-sport boxes out, Quite a good job to do and think afterwards, yeah....i did that!
Got the car back, squeaky seatbelt and boot washer seem to be fixed but il need to go a proper drive to check this,
There gonna order parts and give me a call for the bonnet sensor, clutch and bootlifter as well as offerng new brake disks under warranty due to corrosion and the low milage of the car
So so far so good
Will give a final report when Its all completed
Cheers
