Interior Light
ghettofunkmaster
Hi guys i've got a gen 7 celica (2001) with the electric sunroof,
i need to change the interior light but don't know how to,
i know i need to undo the screw but i'm unsure after that
any help would be appreciated
Cheers
Cheers
yep, that one screw then it should pop out with very little force.
As aquazi says (hi butty! ;)
just take out the screw and then you need to prize the plastics off with a flat heat screw driver or similar.
the sunroof bulb is bayonet (and not torpedo) type, code BA9S
you may like to do like i did and change it to a cool ultra bright LED while your at it.
i got one like this
