Will Tte Springs Lower A Facelift Tsport?
robtheman
sorry if it has been asked.
Does a facelift CTS have TTE springs fitted already? i know they lowered it from the pre facelift version.
Wasnt sure if they used the TTE springs to do this?
yes the TTE springs do lower the facelift Tsport, i had them fitted bfor i fitted coilovers
kool how much to get em fitted?
No they wont lower it if the springs are for the facelift, It already has lower springs, I could be wrong....oh bum....!
IT DEF lowers the car a little bit more, i had the standard springs for the Tsport and then fitted TTE springs which lowers an xtra 15mm i THINK cud b wrong
ERM, i think i paid bout £180 to hav them fitted and car tracked and aligned
You may be right, I think when i swapped my pre face lift to a facelift i parked them side to side and couldn't find a differance!
the facelift is 15mm lower than the original - tte springs will lower original 30mm so i assume the tte springs will lower the facelift 15mm.
I hope so i got some -30mm Eibach springs fitted soon for my prefacelift TS & hope there isnt 2 types by Eibach one for prefacelift & other for facelift, though i did say 2003 year when i ordered them & hope they got it right if thats the case or there be trouble :rolleyes::angry: :o
The TTE/eibach springs will lower the original CTS by 30mm and the facelift CTS by 15mm... just to clear things up! :lol: So £/mm you're worse off with the facelift for this mod! :P :lol:
Don't worry you have the correct springs... they just don't lower the car as much relative to the pre-facelift model so it won't look quite as obvious but is still worthwhile...
