Limiter On Yaris 1.0
puntocit
I find that you can push the revs to their limit without damaging things so long as you don't do it too often!
i'll go through the speeds you can achieve in the gears;
1st - 30mph
2nd- 56mph
3rd - 75mph
4th - 94mph
5th - not sure
it doesn't really damage the engine unless you do this with every gear change... these cars are designed for high revs because of vvti.
it will reduce engine life but if you are planning on keeping your car less than 5 years don't worry
Ok, I understand. ;)
Is it useful to push sometimes the gears to "keep awake" the engine? ("keep awake" = literal traduction of a typical italian expression that I can't suggest better). :eek:
Better to push throught the gears, and get the RPM up before changes, than to change at low revs and have the engine flounder, better Economy too.
Message is you can rev it, and have fun...but don't rev the b:censor:ks off it every two mins.
on all VVTI engines.
they are designed to be rev'ed to the red line i.e about 6000 rpm.....
so wether its the 1.0 or the 1.5 t sport....rev away.....
just make sure you DO get the service done and the oil change.. as thats going to naker the car if you rev it......
(on the celica t sport it revs to 9000.......and you have to rev hard to get the extra power)
Saluti puntocit! Siamo principalmente inglesi tuttavia là siamo qualche gente dal Sudamerica e da altri posti. Il mio italiano non è molto buono ma provo il mio la cosa migliore! :unsure:
Where in Italy do you live? :)
you will need to remap the ECU which means bye bye warraunty (if your cars still under it) and not sure who if anyone does a remapped chip for a yaris.
as far as i was told: no one in europe has been able to remap the original ecu. as a matter of fact, even the tte guys in cologne )after all the official toyota sports dept) are able to do it. They have an extra ecu for the compressor which is kind of constantly "fighting" against the commands of the main ecu...
