Overheatng
rob24
hi for some reason today my surf decided to overheat snd burst a water pipe as i have repaired and sorted problem with fan
It seems to still get quite warm but it taking longer to get there anyone any ideas
thanks
The rad cap is basically a pressure relief valve. It releases built up coolant pressure into the overflow reservoir, instead of blowing hoses off.
always wondered what the spring loaded disc was in the caps well that clears that up
the reason for the overheat was a muddy radiator and fan mesh (there is 2 fans what is the small one for)
The small fan in front of the rad is an electric back-up fan for when the coolant temp gets above 90 degrees, e.g. when stuck in traffic or slow moving when off-road.
my surf has been ok for a few weeks now e.g. not over heatin but just been for a trip up the motorway and its got up a few mm from the red on the bottom temp gauge has anyone got any advice as im meant to be goin to blackpool tomoro please reply asap
I assume yours is the 2.4?
Keep speeds below 75mph, the 2.4 doesn't like it any faster for long periods, causes the coolant temp to rise.
Did you re-new the thermostat?
Make sure the heater is set to hot, including the rear one if you have it, when topping up/re-filling the cooling system, and leave the rad cap off for at least an hour before checking the coolant level and topping up if requiered. Re-fit cap when no more coolant can be added.
make sure the overflow reservoir is at least a third full too!
If your air-con doesen't work, or you're not going to ever use/need it, consider removing the condenser rad and fans from under the engine, this will allow more efficient engine cooling and under bonnet heat to escape.
ive heard that some of them have a wax capsual stat not sure on which engine it is
and ive just taken the oil cap off and there seems to be quite a lot of compression which doesnt seem that cleaver
also i cant find any bleed nipples for the water which ive heard there should be atleast 2
Most stats are filled with wax, and don't worry about the blow from the rocker cover most diesels will do that.
No bleed nipples for the cooling, if you drain it just refill very slowly.
Thanks for all the info guys i think its just the radiator that is still full of mud i gave it a pressure wash today purley just on the rad
and braved the run to blackpool and back and it only seems to get hotter than the half way mark on the temp guage
when you let the revs drop and the engine fan idles causing to heat up so im gonna remove the rad and clean all the beaffles
would be a big help if anyone had any pics on this subjuct
Thanks all
rob
