No Engine Management Light
madteg
Have rebuilt engine just got running after 4 months with no battery on it now i have no E,M,L. Has anyone got any ideas, thanks KEV.
what model is it?
if there is no Battery then do any of the lights work? sorry im a bit lost from your post
Judging by the fact he has a gt4a i'm guessing its an st185. Check your fuses, may have blown one. As said above, check your lights, other dash lights too. Possible bulb blown too???
check the EFI fuse. the ecu connections (and the two plugs under the ecu if a 185) if all is well there check the bulb
