Window Adjustments
my drivers side window is not in the postion it should be, there is a substantial gap between it and the side and top seals thus allowing water into the car when it rains, its not the seals, its the position of the window..
HOW CAN I ADJUST THE ANGLE OR POSITION OF THE WINDOW GLASS TO ENSURE A SNUG FIT PLEASE.???
i have seen it done on pillarless doors before and need the step thru on this one to achieve a dry ride.
Have a look at this see if its any good to you ?
http://www.megaboost.co.uk/bgb/door.html
thank you for that, is it the guides i need to tighten or adjust to ensure a close fit?
i think you need to adjust where they sit, got to do mine soon too
This happened to me a few years back and it turned out that the bolts had sheered that hold the window mech in place!!! Only one bolt was still attached. I now have a trusty block of wood holding up my window until I get it fixed!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
