2001 Gts Acceleration
xxhumdanxx
i've started to notice that when i start my car there's a really high pitch noise in the engine
until it heats up then its finne
another thing is that when i press the gas going 40
the gears drop down to second gear and the car gives a kick to it as it accelerates
another thing is when im stationary and then i accelerate,
first gear only lasts till i go to 20 mph or 4x rpm
any thoughts on what is wrong
and what i can do to fix it
The high pitched noise is likely to be the Auxillary Belt, it's a VERY common problem with the Gen 7.
Your other problem sounds like you have a Tiptronic, these were never available in the UK so you may wish to ask on newcelica.org
