Tinted Headlights/brakelights
Patch_uk
I recon you might have issues in this country using that stuff, the establishment don't need much of an excuse now to pull for the slightest thing.
I think this bit at the end should answer the street legal properties ;)
This lens tinting kit contains a can of coloured tinting spray plus a can of tint remover, two surface cleaning sachets and instructions. Due to the products special transparency properties you can achieve an aggressive but subtle styling that lightly colours the lens with minimal light distortion and reduction. The product is specially formulated to be easily removed if required without causing damage to the lenses. For show and off-road use.
Les
does any1 know where i can get an exhaust the same as that??
Like mine? ;)
I got mine from HERE it was £400 fitted a couple of years ago but I'm sure they are cheaper now
http://www.exhaustsuk.co.uk/onlineshop/ima...roducts/214.jpg
Fits years - 00 - 05
Engines - 1.8 Only
Finished with Quad Exit 3" Slash cut Tailpipes (YTP4)
Made From Grade 304 Stainless Steel Mandral bent pipework to create a Smoother Faster Flow of gasses.
Please specify Year /Model when purchasing .
£425.00 inc. VAT
says its 425 :( i like that aswell
