Celica Engine
andy y411jmj
Hey everyone,
Been meaning to register for ages...
Anyway, iv had my Y-reg celica 140, for a year now, had to buy a new engine for it within a month of buyin it cos a piston decided to go thru the bottom brilliant :angry: so got a 24k milage engine for £950 including postage....
Had the engine for a year now, but has now started making kind of a whistling noise constantly, esecially when cold, quite loud also...think it sounds like its comin from the tensioner but not 100% sure, that or its the fan belt. Any advice???
Cheers Andy.
Hey everyone,
Cheers Andy.
it could be AUX belt slipping AKA fan belt, its on the left hand side of the engine. That makes a squeeking noise though rather than a whistle!! if its not the aux belt then i havent a clue, someone with better mechanical knowledge of cars may be able to help.
have a look at this topic:
http://toyotaownersclub.com/forums/index.p...amp;hl=aux+belt
and this:
http://www.celica-club.co.uk/wiki/index.php/140_VVTI_G7
good luck
if the noise only happens when cold its the aux belt and tensioners needs changing, is about a 200 quid job if you use main dealer
while the engine is noisey get a candle or wax crayon let it run on the v part of the belt if it stops get a new belt . please be careful with fingures
tensioners are prone to going but arnt cheap, if you dont want to put your fingers near rotating pulleys (not a good idea) spray on some WD40 if that works change the belt at least if that dosnt fix it you only need to pay for a tensioner
That looks like a proper ball ache, I got my AUX belt changed a week back £40 from Mr.T. Mechanic I know charged me £45 for the belt and the fitting. Only cause I did it whilst it was up on his ramp xD, wheel off went at it like that. Seriously, don't fancy going at it from the top it was enough of a ball ache as it was. Also, mine required a special tool for a special bolt we found on the tensioner, idk if thats a common Celica thing or just on the imports..
