Jacking Points
kenty
well theres 2 on each side and one under the engine somewhere, the ones on the side are obvious, and the one on the engine check your manual for it.
i know where the side ones are, but its the front and back ones I need to know and I've los.....misplaced my manual. Any help?
Hiya,
I've got a Yaris Manual right next to me and it says that there are only jacking points on the sides behind the front wheel and just before the rear wheel.
This is on page 248.
Hope that possibly helps.
There isnt one on the back. Although if you jack it up under the back axle then stick two axle stands under the side jacking points its ok.
There is one on the front under the engine somewhere.
