What Engines
ReaperGFX
what engines in the toyota range would fit the 140 celica, mr2, older versions of the celica e.t.c without having to modify mountings e.t.c
as if and when this oil consumption gets worse there is a couple of breakers around where i stay so i can keep a sharp eye out for any car that comes in with rear end damage so i can steal the engine
why not get your engine stripped and rebuilt before it gets too bad? pm me if your interested,not too far from you.the problem with getting another engine is you maybe buying the same problem or if you manage to get a late engine,breakers want the earth for them. good luck
