Stereo Removal
dmm86
search for a thread by "man-bing"
in his signature there is a link to a photo tutorial.
yep thats a good guide with pictures. But if you want a quick step
remove the centre dial for i think 1 2 3 4 for how much air you want and there should b a screw. remove the screw with a normal screwdriver. Then take out your ashtray lift up the gear tray with a slight bit of pressure should clip off and then clip off the whole face panel carefuly and after that jus unclip the small connectors going into the back of the dials to take that part off after under the stereo holding it should be 4 spanner head screws id advise to remove with a socket spanner i think size 11 socket was the one but just have a check be careful when removing because the screws fall. Id advise to find man bings post because removing should be done carefully as the things inside can get damaged when pulling them out and you dont want to break anything.
yea im gna light my whole dash with blue neons as i can fit them in need help with the dash dials lol i have big plans for the car!
and i wana spray it purple!
