Engine Rattle
lad
hi ive just bought a 2000 model celica 140 import with 90k on the the clock it has developed a engine rattle that sounds like a mk 3 fiesta ha,it only happens when i want to cruise at high speeds ie 60 mph on,it does have a timing chain which i suspect is the problem hope not thogh,it doesnt use any oil or water either,please help anyone :( :(
Sounds similar to a problem I've got wit my Gen 7 2000, it rattles/clicks or somthin but only at cerain engine revs, higher or lower revs and the noise dissappears. It sounds fine when idling. think i'm gonna go get it checked out, and hopefully it wont be the dreaded oil consumption problem and all that comes with that.
have u got any further in finding whats up with urs?
lots of gen 7s have had this problem its a heat sheld come loose or broken :) and yes all gen 7s are chain and not belt drive for the cams .
I've had a couple of exhaust heat shields come loose over the years on my Gen7. The large rear one has been replaced once after one of the mounting bits snapped off and then the same shield lost one of it's clips. It sounded like a hollow metallic rattle / buzzing, but could only hear it at certain revs.
I fixed it using one of those plasterboard fixing bolts. Now I've got the one up by the exhaust manifold that's loose. I hadn't really noticed this, except a faint buzzing noise on odd occasions, but then Toyota mentioned it to me that it was loose after they had the car in for a service... nice of them to fix it! :(
Think it really needs to be on a ramp to get to this one.
