St185 Fmic Mounting Points?
gezmeister
Hi all
I'm planning on doing a diy fmic install this year, and am pretty happy with core design, pipe route etc. But i'm not sure about the actual mounting position? Where does the fmic bolt to? bumper support? As wherever you mount it needs to take the weight of the i/c and pipework during journeys ie needs to be able to take a bit of vibration over speed bumps and uk sh*tty roads
Any help would be appreciated
Hi all
What size I/C are you planning on using? I made up my own mounts to use a Cossie I/C. Lots of folk cut out the front bumper support to locate the larger type I/Cs. Not a great idea if you end up having a frontal impact.
