Windscreen Washer Pump ?
Vimal
Mt Front windscreen washer pump does not make any noise and no water sprays out.
Does anyone know if there would be a fuse to check for this ?
the back jet washer works fine.
hey ive got the exact same problem on my corolla... the washer pumps gone.. i had my corolla checked out today by toyota and they sed it needs a new washer jet pump.. £50 from then .. and onother £79 for fitting!!! :crybaby:
im just looking for a washer jet pump off the net.. can any one tell us which toyota ones will fit in a corolla? only one from a corolla or any from toyota?? etc
thanks ppl
There's only a limited number of pumps, but it's hard to say exactly which ones will fit. The Toyota ones seem to be different to other makes only in that they have different electrical connections. Otherwise the ones you can buy for £10 - £20 in Halfords would do the trick.
I found that the one in our mid 90s Rolla was identical to the one in my early 90s Celica (ST185) but I think the only way you're going to know for sure what else will fit, will be to take out your washer pump and then go to the scrap yard and find one on another Toyota that will do the job.
If you have a washer front and rear, but a single pump then you'll need to look at other cars that have that same config. A few cars have separate pumps for the front and rear screen, but that's rare.
