Anti Hijack
whitt
is there anyone who's got anti hijack on there t sport or know how to activate it if you can. i have read a thread which had the info to do it but when i tried it dint work.????
its automatic door locking when u drive off, meanings people on the outside cant get in, quite gd idea, i had one on my last clio, kind of miss it. dont think rollas have it tho. in saying that a friend with an ibiza told me 2nite he had to have his turned on by computer. strange
From the users manual :thumbsup:
IGNITION CONTROLLED DOOR LOCK : Door locking while driving controlled by Ignition-ON.
PREPARATION
1) Check that all connectors and terminals of the fitting kit wire harnesses (main) and (engine)
are fitted correctly.
2) Reconnect the negative battery cable.
3) Remove the key from the ignition key cylinder and push the “unlock” button of the remote control.
➨ Indicator lights will flash 2 times.
4) Close boot and bonnet completely.
5) Step in the vehicle and make sure that all doors are closed completely.
6) Insert the key into the ignition key cylinder.
7) Wait for more than 5 seconds.
8) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
➨ Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 6).
9) While the LED is illuminated :
• Open and close the driver’s door 2 times.
• Turn the key to the ACC position.
➨ LED will continue illuminating.
Ignition controlled door lock ON :
10) While the LED is illuminated:
• Open and close the driver’s door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
➨ Indicator lights will flash 1 time.
➨ LED will extinguish.
Ignition controlled door lock OFF :
10) While the LED is illuminated :
Sorry, that's from the TVSS users manual!! :lol:
I have a full PDF of the manual if anyone's interested?
(And can tell me how to upload it on here!! :lol: )
I have the same manual (I've posted a link to it before) and have never been able to get any of the things to work.
