Ajustable Valve On Bulk Head
madteg
How do you set this valve up its under the n/s strut brace i think it is boost control as my ecu keeps going into fail and showing fault 34. THANKS KEV.
the one on the bulkhead is the aircon idle up valve. if you have a bleed valve/relief valve fitted it is that that needs adjusting. (look down at the side of the turbo)
if it is std then you need to look at the actuator (on the turbo) or the pipe work
