Mkiv Headlights - Info Needed
spowiednik
Greetings.
I need informations connected with Toyota Supra MKIV 93-98 Headlights. Questions below refere to oryginal Front Lamps only.
I found 3 models of Headlights:
Combination Lamp Assy 93-96 R 81110-1B170
Combination Lamp Assy 93-96 L 81150-1B170
Combination Lamp Assy 97 R 81110-1B240
Combination Lamp Assy 97 L 81150-1B240
Combination Lamp Assy 98 R 81110-1B241
Combination Lamp Assy 98 L 81150-1B241
I have also seen in net something like this :
The 1993-96 part numbers 81130-1B170 81170-1B170
The 1993-96 part numbers 81130-1B220 81170-1B220
The 1997+ part numbers 81111-1B241 81151-1B241
Noone in Toyota can give me straight answer about differences between these models. So if anyone have any of these lights, please answer folowing questions :
1. Cover - Glass/Plastic?
2. Lamps interior (background) - Silver/Black?
3. Bordering of Lenses - 2chrome rings/3 chrome rings?
4. Most inportant : European Certificate (Homologation) - Yes/No?
If You can link some photos - it would be great. Please write ASAP.
Those part numbers all refer to LHD units which were never sold in Japan and therefore 'should' be glass as all export Supra's had glass as far as i am aware.
96 is when the facelift took place. So 93-96 should be silver and 97/98 onwards should be black.
Hmm, first 3 models should be LHD. Next (4,5,6) are plastic, glass, plastic, or I should say - should be. I hope there will be someone who will compare numbers with Lamps in model. If anyone will give one answer for one model we can put all together than. This is 4 simple questions. I can't find answers (even in Toyota), that's why i wrote this post. This informations will be spread to help others so if anyone can help - do it please.
BTW - nice pic. I'm not sure that this is any of these models but it's quite nice anyway. However i cant put if into a bulbs :D.
