Rattle In Dash
Fred6370
2nd part...
Spots which holds airbag ( never disconnect cable from airbag!! Remove it without disconnecting!!
Just before returning dashboard back, check everything which can make noise just to be sure
Few spots just to be sure that everything is on it's place
On the left only one screw holds dashboard
Few spots where I add sponge
Blue circle holds taho
Everythin on it's place
I hope that You will figure it out if I miss something to say, it's easy to do that all!!
If You do that you will not recognized Your car when you will go out for driveing.
P.S. Sorry maybe for my english, i try to explain on the best way rolleyes.gif
2nd part...
Hi drobotic,
Just found your very useful instruction with the pictures attached. As you have taken the dashboard off and put it back to its previous position, maybe you could remember the cup holder on the passenger side and what woulod be required on purpose to replace it, i.e. would it be required to take it out all the dashboard or it would be enough just to lift up the right side of the dashboard and get access to the cup holder.
Any thoughts would be very helpful.
atex
  • 4 years later...
On 2/26/2008 at 7:40 PM, drobotic said:
2nd part...
P.S. Sorry maybe for my english, i try to explain on the best way :rolleyes:
Sir, please re-upload photos, links seems not valid
