Replacment Of Bulb Behind Heater Control
wipid
I have just bought a corolla 1.4 g vvti (2001 model) & would like to know how to replace the bulb for the heater control.
I am also a new member could someone please help???? :(
Is your switch near the top of the dashboard?
You should be able to pull the twisty knob off the front quite easily (can on my older roller) not sure about the newer ones and then it should be right there, but Toyota could have put them behind the dash now making it harder as you will have to take bit out and remove part of the dash to get at them
