Changing The Seakers
famo
  • 2 months later...
O/S/F or N/S/F door panel. Either way pretty much the same, gently remove fuel release button on driver door or trim piece on passenger door. If you look up at slight angle you will see 10mm screw/bolt, remove this. Then behind inner door release handle you will find small screw to remove. You may have 1 screw behnd electric window switch pack, leave to last just in case. Door panel is fixed to door assembly with little plastic push-in buttons, if you do not have proper trim remover use large flat blade screwdriver to pop panel off. Do not use small screwdriver it will cut into & damage your door panel. You should now be able to lift panel upwards and away from the door, be careful with any electrical connections as you remove panel. Rear door pretty much the same process. Hope this is of help.
