Turbo Timer
paul4
Have recently bought a hilux surf fitted with a fet tb 308 turbo timer no instructions. Looked on internet but can only find wiring diagram. Does anyone have any idea how to operate one. Your help would be greatfully appreciated
Hi Paul, I have a turbo timer on mine. It can be set from 1 to 7 minutes by just pressing the button. I usualy set mine for 1 or 2 minutes,longer for long distance. With mine when I stop after a run, while the engine is still running, I set the timer for either of the previously mentioned times. A green light comes on and the ignition can then be turned off but the engine still ticks over for the specified time. Hope this is of help as I would think they all work in a similar way.
Ricster
Ricster
Thankyou
