I have a 1999 Toyota Corolla with 67842 Mi and the Check Engine Light is on. I checked the engine fluid and everything is OK. What else could it be?
The light from check engine flickers normaly a code
like it flickers 2 times then a few seconds not and the it flickers 5 times than thats the code to check ( 25 ) than you can ask what the code is and check the parts where the code stands for ;)
if ur engine warning lights is on .....there is many things could possible happan...but most of them are electrical problems , so the best way is take ur car bak to the main dealer and re code it....coz sometimes it just come on with no reason....so i higher recommened u to check it asap
