Door Speakers
knightrider
i'm after some new door Speakers for my yaris and would like 2 kno wot is the maximum size u can get in them also does anyone have a template for MDF backs?
cheers
lee :thumbsup:
ive got 6.25'' Speakers up front but its a squeeze to get em in
ive got the mount template somewhere ill try an sort it for ya
how did you remove the speakers
5mm drill bit to remove the rivets..
jaxx.. 6.25" :eek: what make are your Speakers? i tried some pioneer 6.25 and they just wouldnt fit.
ive got 5.25's in wot should be the standard Speakers but apparently MDF should give better quality,
jaxx that template would be a great help if you could find it
cheers
lee
so after drilling the rivits out do i just put the new ones in?
alpine sxs1757's
ill get the temp as soon as i can i need to reload autocad onto my computer cos thats what i designed them on but i can mail you a full size picture and then just pin it down and jig it out
i actually CNC machined mine out of MDF at work!
:thumbsup:
yup, i used 5mm nut and nylon bolt.
what are nylon bolts? can I not use normal bolts, so Im assuming I still keep the black plastic bit arround the speaker just change the speaker
have ya got a recent copy of auto cad vmail?
nylon nuts are the locknuts with the nylon ring in the top
I can get any software (yes). are the nylon nuts black or blue and it looks like there is a washer stuck to it
they normally look like a normal nut with a blue nylon thread on the inside, don't think you have to use them. I only used them because i have loads lying around and they are less likely to work themselves lose due to vibrations etc.
got any pics? can you put nuts on them, if so then I know exactly what you mean
