Rad Draining Caps ?
mattmunx
Hi guys need a little help here , im trying to drain the rad in my 1993 2.4td LN130 SSR-X surf , looking in the owners manual it says remove the rad draining caps , i cant see them ive looked for ages , are they obscured by something else ????
its says one is on the bottom of the rad ( i think ) but i cant see it , and one somewhere else .
every time i get a problem you guys always help me out so thanks in advance as any help would be great .
cheers matt :-)
Not a bad thread, I would just mention one thing
Toyota coolant, if you use it, is already the correct strength, you dont mix it 50/50, with distilled water, which does mean you will need 10 Litres and not 5 as mentioned
Kingo :thumbsup:
