Tyre Pressure?
S.Kayani
Hello, i recently changed tyre's but not sure on the correct tyre pressure i should be putting in? I previously had 185/65/14 tyre's with 33psi at the front and 30psi for the back, any ideas on what it should be for 195/45/16's? Cheers!
don't know what the exact or correct air pressure is, but I put 32/33 front and 30 rear.
More in the front because of steering and the weight of the engine, and my fat ***** :lol:
bout the same then? cool
if no one else says any different ill prob end up putting the same in
on a side note i do quite a bit of driving at 40-50mph driving if that makes any difference
