Sat Nav And Speed Cameras
Groovy Mucker
The Sat Nav in my Avensis doesn't seem to have speed camera locations. Is that right, or am I missing something? It's the TNS 700 system I think.
Hi im new here, but jus wanted 2 ask sumthin. just bought an avensis T4 1.8 dat has a TNS 200 but i can seem 2 get it 2 work. it just says insert CD. can any1 give me any directions as 2 how i start off. NEED REPLIES ASAP PLEASE AND THANK U. :(
Hi
You need to check if there's a disc in your sat nav DVD, it's probably under the passenger seat. Get in the back and look under the passenger seat, remove cover and push the silver switch to the right, if there's a disc in it will come out! If a disc does come out and it is a Toyota Sat Nav disc then either the disc is dirty, faulty, or your sat nav is! If no disc appears (which I suspect will be the case) then you will need to obtain a maps DVD in order for your sat nav to work! You can ask your dealer, or see toyota map-updates, I will warn you though, Mr T will charge you over €100 for this. Alternatively you can look on e-bay and there's usually some for sale, or you can download them (if you can find them) and burn onto DL DVD+R, the file is over 7Gig so it has to be DualLayer, and I think only +R discs will work.
Hope this helps.
:D Ben N 74 :D
