Cars Back From Warranty Work
Demo_202
Well a few weeks ago the car headed in with a few problems,
- rear washer schooshed everywhere but the rear window
- boot lifter rusty on passenger side
- alarm bonnet sensor going off
- squeaky clutch
- squeaky drivers side seatbelt
1st round: seatbelt and washer sorted and the parts ordered
1week later
round 2: boot lifter fixed, and alarm sensor fixed (as far as I can tell) clutch done but apparently another item required, also got new discs as the corrosion was above what it should be at 20k
Today
Round 3: another thing done with the clutch, girl couldnt tell me what but it does now feel alot lighter... but.. using the clutch while pushing the car a bit means grooaaaaaaaan.... obviously not happy about that but everything else has been sorted. Really cant be ubikd going back though
Just thought id fill you all in
Cheers
My clutch also made the same noise when being pushed and the clutch also felt strange and it was serious enough that the car is having a new clutch and master cylinder done under warranty. I would take it back and say it has still got the fault and try and get that done under warranty coz i would dread to think how it wouls cost to get it done whe you rwarranty runs out
My Clutch pedal squeaks, I just thought it was a squeaky pedal. Should I get Toyota to have a look? I am still under warranty.
Its more of a groan than a squeek, like when the car goes over say 5000rpm and you use the clutch
Whens yours getting done Dave?
