Handbrake Adjustment
IanXT4
I am looking to adjust a handbrake on a Petrol XT4 4.2 which has I believe rear drum brakes inside the disc hub. I have read somewhere that I need to check the drum brake pad clearance, before I take up slack at the handbrake under the center console.
Does anyone know how/where to check/adjust this clearance and what it should be
Many Thanks
Ian
Seems to get slack very easily. I was charged £25 at a standard service t have it adjusted-claimed it took an hour to do it but they would only charge in for 1/2 hr. I pointed out that when I had owned other brands , handbrake adjustment was considered part of the deal. Got it knocked off but I don't know if it was try on
I've got all the photographs to support a "maintenance tip". If you can wait until weekend I will show you.
Thanks,
I think it can wait till the weekend :D
