Oil Dripping From Front Of Vehicle
collywobbles69
This is a silly question but where would it poss. be coming from? It has only happened in the last day and is not the oil filter but appears to be coming from front diff. It is leaking onto the lower cooler cos I removed the protective tray and could nt find its source. Has anyone got any ideas???
check the sump bolt, had the same problem for 3 years on theYaris and toyota could not fix/replace it
Toyota couldn't replace a sump bolt???
